Message |
- check & replace accessory belts if needed - inspect & replace brake pads/rotors if needed - clean your air intake filter - check power steering fluid - see what your battery amp draw is - what shape are the tires in? If you have access to a lift: - checking exaust bolts to see if any have loosened - checking for fluid leaks in the back engine/trans area - checking for power steering fluid leaks And of course: Clean and wax that thing! Cheers,
![](http://www.atonal.ca/rzadtrack.jpg) ![](http://www.atonal.ca/ttnetsigs/vorpalbw.jpg) ![](http://www.atonal.ca/fallvert.jpg)
MY Zs ARE HYBRID VEHICLES, THEY RUN ON GASOLINE AND MONEY "I expressed no attitude, I'm correcting you. If you don't like it, try not to be wrong next time. Now you're getting attitude, and if you don't like that you should grow a thicker skin.” - TriniTT 14:04:16 12/22/12
”Exhaust doesn't produce horsepower” - VERTTZ 13:17:22 06/26/12
I'm off to wax mine and go for a drive now. - BigTDogg (MA) 07:17:08 07/17/09 times change, people change, but the Z32 still kicks ass. - apudapus 16:46:02 06/15/07I was more wondering how you set your climate control to 22* lol, it would be that fastest freezer on wheels! - Briscoe'sZ32 (NJ) 23:15:44 02/05/07You have *got* to be getting a cut from B&B :D - SeedyROM 15:24:29 08/16/06 What do you think B&B stands for? - YugoBernie (NoVA) 15:57:09 08/16/06
![](/themes/01/images/spacer.gif) |
